Old 04-04-2023, 02:09 PM   #5 (permalink)
redpoint5
90 day: 38.47 mpg (US)
I hear you on metal or 2" water pipe posts, but sometimes you're stuck having to use wood, because.....
Only issue with metal thats bad is when something comes through your fence and you have to replace posts, then you gotts pull the concreta also
Metal in concrete is the same problem as wood in concrete though.
Is concrete necessary with metal, or can you use sand?
... and whoever has come through my fence is going to pay to fix it... except I'll probably take the check and fix it myself.
