Old 04-09-2023, 03:17 PM   #3 (permalink)
freebeard
Don't use water, use Turbo Rocket Fuild™.
oldsjetfire.com › jetfire-turbo-rocket-fluid
Jetfire Turbo Rocket Fluid - OldsJetfire.com
The original anti-detonation fluid was straight water, but that would freeze in the cold climate states, so methanol was added to suppress the freezing point. The Olds engineers found the mixture with methanol actually gave the engine about a 5 horse power boost, bring the rated horse power up to the magical 215, 1 HP per Cubic Inch!
If you bootleg it, don't forget to wear your gloves and beware invisible flames.
