Old 04-17-2023, 06:52 PM   #34 (permalink)
Cd
Ultimate Fail
Cd's Avatar
You guys were right. I'm learning.
Beating up the metal did not make it more rigid.
I also found that removing the 1/8" foam backing did nothing. There is the same, if not less noise, and just a bit less frontal area.
I tested the area of the wheel that rubs.
I was surprised to see that the sidewall doesn't even make contact in full turns, despite having a raised ridge .
The areas that do rub are the top corner where there is blue and green paint.
