Old 04-10-2023, 10:58 PM   #31 (permalink)
Originally Posted by Cd View Post
My mistake - I meant make it more rigid.
But that's probaly not correct either.
Thermical treatments are meant to increase rigidity, as they decrease tensions which are caused by the impact while moulding/forging.
Old 04-10-2023, 11:03 PM   #32 (permalink)
Don't lose your temper.
Old 04-14-2023, 06:17 AM   #33 (permalink)
I knew you would get the reference
freebeard (04-14-2023)
Old 04-17-2023, 06:52 PM   #34 (permalink)
Cd
Ultimate Fail
Cd's Avatar
You guys were right. I'm learning.
Beating up the metal did not make it more rigid.
I also found that removing the 1/8" foam backing did nothing. There is the same, if not less noise, and just a bit less frontal area.
I tested the area of the wheel that rubs.
I was surprised to see that the sidewall doesn't even make contact in full turns, despite having a raised ridge .
The areas that do rub are the top corner where there is blue and green paint.
Old 04-20-2023, 12:42 AM   #35 (permalink)
Didn't really surprise me. The tread is usually much more critical in that regard.
