Old 05-05-2023, 04:00 PM   #97 (permalink)
redpoint5
90 day: 38.47 mpg (US)
How hard is it to rekey an ignition?
Do you have the nicest Metro in the neighborhood?
When some tweaker screwed up my door lock by jamming something into it, I removed the tumbler, inserted the original key into it, and used a bench grinder to grind the pins flush with the tumbler again.
I imagine a similar method might work for the ignition if it uses a tumbler.
