Old 05-13-2023, 10:37 AM   #2 (permalink)
Piotrsko
Typically you check random cells to see if they are within a range of .02 volts between max and minimum meaning they are balanced in capacity during discharge.
Without long testing through several cycles, that is the best you can do other than ensuring the pack is above recommended storage minimums for the cell chemistry/count.
Fla you could check the negative most batteries but that isn't relavant any more
