Old 05-31-2023, 05:47 AM   #1 (permalink)
Zoid driver
Hi! New member. 2000 Honda Insight.
Hello. I made a long post as my first post in Aerodynamics about my full boat tail project. It was lost. Lesson learned. This will be a test. The boat tail is 32 inches long and made with aluminum angle and skins of aluminum trim coil. This is the stuff you bend up and trim around the windows on your house. I found some on clearance at Lowe’s. I started on April 18 and am fitting the skins now. I am using aircraft tools and rivets. It looks better than you would think. I spent a lot of time lining up the stringers so I could use flat metal.
2000 Honda insight
Full boat tail in work
EPS delete including pinion gear
Interior delete, trim, carpet, everything
Radio delete
Rear wiper and motor delete
A/C delete
FAS switch
Calpod switch
10 ah LIFEPO4 battery
Upper grill block
The Following User Says Thank You to Zoid driver For This Useful Post:
Gasoline Fumes (05-31-2023)
