Old 05-31-2023, 04:47 AM   #1 (permalink)
Hi! New member. 2000 Honda Insight.
Hello. I made a long post as my first post in Aerodynamics about my full boat tail project. It was lost. Lesson learned. This will be a test. The boat tail is 32 inches long and made with aluminum angle and skins of aluminum trim coil. This is the stuff you bend up and trim around the windows on your house. I found some on clearance at Lowe’s. I started on April 18 and am fitting the skins now. I am using aircraft tools and rivets. It looks better than you would think. I spent a lot of time lining up the stringers so I could use flat metal.
2000 Honda insight
Full boat tail in work
EPS delete including pinion gear
Interior delete, trim, carpet, everything
Radio delete
Rear wiper and motor delete
A/C delete
FAS switch
Calpod switch
10 ah LIFEPO4 battery
Upper grill block
The Following User Says Thank You to Zoid driver For This Useful Post:
Gasoline Fumes (05-31-2023)
Old 05-31-2023, 10:44 AM   #2 (permalink)
Welcome to Ecomodder.
When you get enough posts, we can see some pictures.
The older I get, the better I was -- John Fogerty on Joe Rogan
Old 05-31-2023, 12:02 PM   #3 (permalink)
Current state.
2000 Honda insight
Radio delete
A/C delete
FAS switch
Calpod switch
Upper grill block
Gasoline Fumes (06-02-2023)
Old 05-31-2023, 12:09 PM   #4 (permalink)
That's all simple curves? It looks good so far.
It used to be that it took 5 or more posts to be able to post pics. The mods move in mysterious ways.
Old 05-31-2023, 02:38 PM   #5 (permalink)
Just finished drilling the upper left side skin. All simple curves. Every point on the back of the original car body is continued back without a change in direction. It is as if Honda intended the car to be finished in this manner.
2000 Honda insight
Radio delete
A/C delete
FAS switch
Calpod switch
Upper grill block
The Following 2 Users Say Thank You to Zoid driver For This Useful Post:
freebeard (05-31-2023), Gasoline Fumes (06-02-2023)
