Originally Posted by ttrainxl
Where did you remove the vacuum hose from? The hose has to have two ends, so connecting one end to your new vacuum tube thingy must mean that another vacuum nipple doesn’t have a hose on it.
It goes to a nipple on the intake manifold. One of the tubes is connected to the brake booster line.
IM vacuum port -> tube #1
IM brake booster port -> tee -> brake booster for one connection & tube #2 for 2nd connection
