Recent Changes:
Around 200,500, I changed the oil for the first time in nearly 2 years, and about 15,000 miles. Don't worry, though: I was using Amsoil Signature Series 10w30 and a Fram Ultra Filter, which is as good as an Amsoil Filter, only cheaper. At the same time, I took the oil pan off and made a new gasket for it, since I wanted to keep oil from leaking. I still have to re-gasket the Valve Covers, though.
I also changed the Air Filter with a FRAM Ultra (I was at least 25,000 overdue,) then shortly after that, I plugged the Warm Air Intake with the rag plug from the Cold Air Intake; I was getting tired of the low power up hills.
Lastly (after the most recent fill-up,) I need to get new tires soon anyway. Because of that, I've aired up the Front to 48, and the Rear to 53. That's working for maybe 1 MPG compared to 44 / 48, according to my gauges so far (though I'm not even 50 miles in.)
Recent Tanks:
The last 3 are averaging to 17.8. Two of the tanks were dragged down by me going to yard sales for 2 weeks in a row, and I expect this tank also will turn out lower than it could have been, because it's yard sale season.
I really need to get on the ball with that rear wheel skirting. I don't expect a giant difference, but it should help.
The Block Heater, in this 60 - 85 F degree weather, can usually get the engine to around 125 - 144 F before I start it. That's not accounting for after the antifreeze circulates through the engine, which lowers the temperature.
Idea for Mod:
Maybe one can call it goofy, but I've had the idea of making a Transmission Pan Heater with an old Waffle Iron that's kept at a low temperature,depending on the weather. If I can attach it well, and prevent water from getting in, I don't see how this couldn't be a very cheap and efficient way of slightly warming up my transmission before starting the car. I do have a dented 1960s Waffle Iron that I paid $1 for in a yard sale, and it's not doing much good with waffles anymore - the top and bottom don't line up quite right.
