The pressure washer specific not to 6,000psi fluid filled gauge came in, so did my tachometer.
Knowing any speed and force gives me horsepower. Gpm is speed and psi is force, so...
My pressure washer dynamometer helped me find a half horsepower.
I found a little hack that gets any Honda digital ignition a few degrees of timing advance at full speed.
So I did it and picked up 4 degrees of advance at 4,000rpm and probably about a half horsepower as the engine tuned faster when held wide open, hitting higher rpm, which means it pumped more and at increased pressure.
It was about 100psi more and 0.1gpm more.
