Old 07-23-2023, 08:34 PM   #12 (permalink)
freebeard
Turns out it's a bad idea.
www.speed-talk.com/forum/viewtopic.php?t=7271
Yes it mixes well with alky. It's measured out with a hydrometer not volume. You must be aware that most of the guys that really know nitro have paid for their education with broken parts. Even if you get their engine combinations and fuel curves and tune set ups, your going to break engines badly. It's just the nature of the fuel. First the Nitro is very expensive, then you have to optimize your engine to run any amount that would show you a gain. ... The more you use the lower the compression ratio needs to be. Temperature control to fuel ratio needs to be addressed. This is for smart guys with deep pockets,.. Even if you think just a little. you will find you keep tipping the cam saying that didn't do any thing, that didn't do anything, then OH OH that was too much. If you do try it Remember the first rule of Nitro, get engine hot then feed it all the fuel you can. You are never too rich, you just run out of heat, air or ignition. That sounds funny, but if you run out of fuel you will say ouch.
