Thread: Wood chip fuel.
Old 07-30-2023, 10:29 PM   #68 (permalink)
oil pan 4
I have added an oil filter to the wood chipper. Used a 0.088 inch turbo oil restricter fitting to return the oil to the oil drain hole. I used the smallest oil filter I could find without a built in relief valve.
That cuts my oil pressure just about in half. Need to restrict that down a bit more. Want to be back around 40 or so.
Now I should be able to do 50 to 150hr oil changes instead of 20 to 25. Now the oil I dump out at 100 hrs will be cleaner than the oil I would dump at 20hrs.
