How have you other Volt owners kept track of refueling? I could have zero or a couple dozen charges between getting gasoline. Is there a good (not super tedious) way?
I just took our first 'longish' trip of about 200 miles. I had about a half hour to recharge at one point, so I didn't get too much above the normal EV range. Here is the result. Not too bad. I'd say the Prius probably would have done about 50 mpg under the same driving.
