Old 08-25-2023, 12:31 AM   #5 (permalink)
razordave
Not exactly what I had in mind when I mentioned using motorcycle tires in a car with such an extreme camber. On a sidenote, once in a while I see cars with that space-saving spare fitted with a motorcycle tire, as it's easier to source than those specific tires meant to be used as a space-saving spare.
I actually just took a much newer space saver and added to a rim that technically doesn't fit my car. I was toying with the motorcycle tire until I sourced both the wheel and tire for free.
I would like to find a pair of space savers for the rear of my beetle, I know they're for temporary use but I once saw a front wheel drove drag racer use at least the wheel for an advantage.
