Old 08-28-2023, 08:57 PM   #7 (permalink)
redpoint5
90 day: 29.78 mpg (US)
I imagine a supercap bank would prolong the life of the battery, but currently I see no need to overcomplicate it if it's working well. Have you done any testing with just a lithium pack?
Ocean/coastal application is ideal as it rarely freezes in the lower 48.
I have to relocate the battery inside since it freezes here. That means I have to find space for it, which the glove box lends itself to. If I want to start off an internally located battery, it has to be large enough to supply the ~300 amps, and I'd have to pass the enormous cables through the firewall. My setup seems less complicated. I'm happy with it so far.
I did try a lithium ion battery as a virtual alternator delete, but I need thicker gauge wire to do that properly, if it can work long term at all.
The Following 2 Users Say Thank You to redpoint5 For This Useful Post:
Ecky (08-28-2023), razordave (08-28-2023)
