Thread: Wood chip fuel.
Old 08-30-2023, 05:07 PM   #78 (permalink)
oil pan 4
Well, an "oversized" oil filter also often provides a mild oil cooling somehow.
Well now that you mention it I guess the oil filter does increase surface area that the oil comes in contact with quite a bit. I should run it, close the oil filter valve for a little while open it and see if I get significantly hotter oil to the gauge all.
