Old 09-14-2023, 03:40 PM   #74 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
Originally Posted by djr48312 View Post
Was your 1.15 lambda lean cruise on E85 considered a success? I have been figuring that E85 should be able to cruise on a more lean value that gasoline due to it's cooling properties and resistance to detonation.
Gasoline really shouldn't have any problems cruising lean anyway. It's running just shy of stoich that's a problem, and the crossover from lean to rich. Lambda ~1.03 and above 70% load is the point to keep an eye on at typical cruising RPM.
