Old 09-28-2023, 11:57 AM   #778 (permalink)
aerohead
'how to keep from rubbing'
Only question I have: driving on a typical highway, how do you keep from rubbing the tire with the gap filler. After a while it's going to be almost the size of the original wheel well opening.
The final dimensions are chosen when wheel-flop, lock-to-lock, with full vertical suspension travel fail to make contact.
Ablative urethane foam will 'lap itself in ', taking on a 'zero-scrub' clearance.
