Old 10-08-2023, 03:58 PM   #241 (permalink)
Isaac Zachary
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
I've said it elsewhere, but I spent 90 minutes concocting a weird setup of swivels, adaptors, and ratchets to remove the 2 bolts that hold the cam chain tensioner on my Honda motorcycle. The manual specifies a silly amount of disassembly to reach that part, so I went a different direction. Then, I spent 3 hours trying to get the 2 bolts back in. Their extreme disassembly might have been about as fast.
The stupid part has like 7 revisions and still makes a godawful buzzing sound after just a couple hundred miles. Common advice is to replace it with a manually adjusted tensioner.
Again, depressing.
On the other hand, at least vehicles last longer and need less maintenance.
If only there were a way to combine the two, have a car with 2020's safety, reliability and emissions and as easy to work on as one from the 1970's.
The Following User Says Thank You to Isaac Zachary For This Useful Post:
redpoint5 (10-08-2023)
