Old 10-12-2023, 06:25 PM   #1 (permalink)
jeff88
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
How to Determine Most Efficient Tire
Hi guys, I'm looking at new tires and unfortunately the specs available are just not that great to compare which tire is most efficient. I know LRR is the big spec to effect efficiency, but it seems weight is the only spec I can find and even that is difficult as I have to really dive into the Google to find it.
Is there a way to compare which tire is more efficient? I know they measure LRR in kg/t, but that spec is just not provided anywhere.
If it helps, I'm looking at a 265/70R17 tire although the width and height are subject to change depending on what's available.
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
