Old 11-26-2023, 05:34 PM   #32 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 59.95 mpg (US)
Originally Posted by Engine1776 View Post
Ecky, I am currently getting 40.25 MPG highway MPG over the last 6 months with the D15b7 motor coupled to the 4.025 Final Drive transmission for a freeway cruise speed of 3100RPM at 70mph.
I religiously separate my highway and city miles.
My "city" (rural sprawl area) MPG is much higher due to hypermileing by accelerating from a stoplight or up a hill, and then gliding down the other side with the engine off to the next stoplight. I live on top of a hill, so the first mile of my drive every day is done with the engine off until I get to the bottom.
Just filled up with gas again in prep for a drive on the highway tomorrow. was down to only 2/3 tank remaining.
Over the last two weeks of ONLY driving on the rural roads around here, i have traveled 220 miles on 4.475 gallons of gas for 49.27MPG.
I think it will do a lot better on the highway with a gearing swap.
Fantastic numbers. I was able to pull off a 50mpg trip with a B18B engine and transmission with a 4.40 FD, but it was using every trick in the book and not at all realistic or representative.
With my K24 swapped Insight, ~40mpg was normal in in 5th gear (I didn't have 6th at first), while 6th gear was closer to 45 (+/- 2mpg) when cruising. Taller gearing seems to be the single best mod for highway driving.
