Thread: Gasoline VAPOR?
Old 11-28-2023, 10:34 PM   #81 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 58.53 mpg (US)
Originally Posted by racprops View Post
Sorry NO the don't The burn cycle is too slow to fully use 100% of the fuel other wise we would be told to cut out the cats as they are no longer needed.
Rich
Two major functions of catalytic converters are to convert carbon monoxide to carbon dioxide, and to convert nitrogen oxides to nitrogen and oxygen.
A quick search reveals this on ResearchGate:
https://www.researchgate.net/figure/...fig4_329043343
Comparison graph of HC level with and without a catalytic converter in RON 88.
If hydrocarbons are at ~80 parts per million, that is 0.008% HC by part.
Fuel and air ought to be at a 14.7:1 ratio, so adjusting for ratio, the unburnt portion of fuel coming out of the exhaust is 0.054% of the fuel that went into the engine.
0.054% unburnt still means that you get a tenth of a gallon of gasoline vapor dumped in the air for every gallon of gasoline liquid which is sent through the engine.
