Old 12-09-2023, 04:00 PM   #20 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Congratulations, Xist!
And if you take a bit longer to finally do it, then no worries. The best things come to those who wait
If you're considering a need to dead bolt an interior door to keep the other occupants out, I suggest a need to reconsider the current arrangement.
I also wanted to propose this - it is not a problem with the door or its lock, it is a problem with needing one in the first place.
It is about correct communication and respect.
But I also appreciate that not all interpersonal relations are what they could or should be, though I assume you have tried your best in that matter, and the rest is not in your hands.
I can only wish you luck in this dimension, and hope that what is lacking in family relations does not cast a shadow on the new relationship you are building.
The Following User Says Thank You to Piwoslaw For This Useful Post:
Ecky (05-25-2024)
