Old 12-18-2023, 12:27 PM   #22 (permalink)
aerohead
'variables'
Originally Posted by yabert View Post
There is way to much others variables like air temperature, wind, etc, to end with interesting result doing this.
I know my power requirement in direct in my Vanabolt dash (like every Bolt).
At highway speed, on cruise control, this one can vary from 16 kW up to 50 kW for different reasons.
So I'm not interested to take huge amount of time doing foam prototype to have barely noticeable result or clearly wrong result.
My goal is simply to build (1 time) a high-top with a good shape who can potentially increase my range.
It will not be the perfect shape, but I'm trying to have as much information/knowledge as possible to not building something bad.
It seem like I will not find 3D flow simulators help here, but what can be a first ''accessible'' book to read about vehicle aerodynamic?
Accessible like I can understand at least 1/2 of what I read
AeroStealth and I conducted some regen/mpg tests on his BOLT over the Thanksgiving holiday.
It was very straightforward, and once the display settled into the 'new' driving mode, the miles/kWh displayed a constant readout until we 'changed' what we were doing. And since the data capture occurred within 'minutes' of the specific 'baseline', there was virtually no way 'environmental factors' could have jaded our results in any meaningful, quantitative way.
If you took the 'less-than-two-hours' to mockup and install some version of one of your teardrop extensions, and road-test it, within a few minutes you could remove the entire thing, and immediately re-test for 'baseline,' before your local air density or ambient wind had any opportunity to change in any significant way.
If you mentally rehearsed, you and a 'helper' could dissemble your mockup with a box-cutter, while it's off the van, recut the foam sides along pre-marked lines, re-tape the roof on, re-install, and re-test, before local weather conditions drifted, capturing the second roof shape.
AirShaper will cost you $4,000 per iteration. $16,000 for the 4- designs you've depicted. If there's anything wrong with your 3-D scans, your results will be garbage.
Dassault ( Exa ) Powerflow, or SIEMENS Star CCM+ CFD sales persons won't return your calls if you contact them requesting pricing, and multi-core time-share processing time.
Wind tunnel time will run $600-$4,000/hour, depending.
All the aerodynamic books in the world will not 'tell you' specifically what your Cds ( CdAs ) will be, for what you're doing.
freebeard (12-18-2023)
