Old 01-02-2024, 05:09 PM   #46 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Your Jetta is gas and mine is a diesel but you can look at some of the photos of my car for some of the aero mods I did. You may not want to cover the exhaust pipe because the gasoline version runs much hotter than the diesel.
PS- I stuffed pipe insulation in between the grill bars. It is easily removed if you are running warm.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
The Following User Says Thank You to COcyclist For This Useful Post:
V6MustangFTW (02-15-2024)
