Old 01-02-2024, 08:58 PM   #3 (permalink)
Fïve1EïghtTDï
Outside of the box
Fïve1EïghtTDï's Avatar
Well you lurked for seven years before posting, so there's that.
"...an alh/bhw hybrid build"? Explain like I'm five.
A BHW is a pd tdi 2.0l only ever offered in America in 04 and 05 passats. The bottom end of this engine is the only one of its kind to my knowledge. Bigger crank mains, bigger rod journals, more robust rods and of course, 2.0 displacement. Because it's a pd block, it's very Sunkist to ve injected engines. With little drilling and tapping of the block, balance what delete kit with a different oil pump, a ve timing set will bolt on allowing to run with ve management and injection pump. The alh has will not right on. This combo is more budget friendly than fully building an entire alh tdi and is capable of same power of not more than building the alh. Everything else is not on. It's an excellent choice for a big power build like compound turbos. That coupled with the entire Quattro setup I have from a tt225 should make a nice 4x4 lifted golf and with the trans ratios, I will be able to run a 32 or 33 inch tire with extremely similar rpm to mph as a stock tdi trans on stock tires. I'm hoping that build will stay somewhere in the 30+mpg range. Far from an ecomodder but still eco friendly at the power levels in looking for and the fun factor it'll be capable of.
The Following User Says Thank You to Fïve1EïghtTDï For This Useful Post:
freebeard (01-02-2024)
