Originally Posted by Piotrsko
Only thing I would change in the above is the larger rim had more mass, not necessarily heavier unless proven wrong by a scale.
However really nice summation of removing factors. Didn't address areo result from ride height changes
Shouldn't be any ride height change, given they're larger diameter "rims" fitting a tire with the same outer diameter. You get a higher moment of inertia but the overall rolling circumference is the same.
