Old 02-21-2024, 12:01 PM   #49 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Originally Posted by Andyinchville1 View Post
I have a 2003 Jetta Wagon TDI (5 speed) and on factory steelies and ecopia 195-65R15 tires @ 44 psi I used to average about 47 - 48 MPG ..... I switched to lightweight wheels (Volk TE 37) and larger tires (215 - 75R15 Hankook tires at 51 psi ( I'll have to look at the model) ) and got basically about 9 percent better fuel mileage
I am curious how you measured your miles, before and after. A change in tire diameter should throw off your odometer. I have used a GPS and found the VW speedometer/odometer to be slightly off even with the original tire size. That said, a taller tire should make your mpg worse on the factory odometer, right?
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
