After installing a set of 19'' wheels on 245/40/r19 tires.. there are tucked in under the fender edges, but because of how the Connect van body is shaped (inward at the bottom) the tires are sticking out. Plus adding that size of wheel/tire has lifted the van up.. thats almost a 8-10 gab under the van and not very desirable. So I'm considering some sort of side skirts for the van. Don't want these things sticking out like a sore thumb so maybe tuck them under the van and mounted on the pinch seam.
Plus with the front of the van tilted up because we've lowered the rear, I don't want to install lowering springs on the front, but will have to consider a splitter.
