So after careful searching, I've located a company who manufacture all types of rubberize moldings and gaskets.. Within their site, I locate an "L" shaped corner molding they already manufacture for outdoor steps and other edgings. This edging is 50mm x100mm x 12mm thick and can come in any length. I've sent word tot he company asking for a quote. I suspect thta I'll need approx 24 feet of this to cover both rocker panel sides of the van. but as I said, I'm not willing to drill holes into the rocker panel.. Unless this L shaped molding can be mounted under the rocker panels onto the plastic trim molding. But would 12mm be thick or stiff enough to offer a good air flow resistance at the lower rocker panels.
If I get a quote back and it's reasonable.. I may order and install this on the van. Plus I have other things that need to be completed before a certain time and I've scheduled time at several road course race tracks to test this set up.
