Old 03-14-2024, 09:47 PM   #1422 (permalink)
redpoint5
90 day: 38.47 mpg (US)
Did that research include the Beaufort Gyre?
Found the first time I mentioned it.
https://ecomodder.com/forum/581116-post3170.html
The URL no longer works. I wonder why?
Found it in the wayback
https://web.archive.org/web/20190819...ry-on-warming/
There are many likely effects of climate change: positive and negative, economic and ecological, humanitarian and financial. And if you aggregate them all, the overall effect is positive today — and likely to stay positive until around 2080. That was the conclusion of Professor Richard Tol of Sussex University after he reviewed 14 different studies of the effects of future climate trends.
To be precise, Prof Tol calculated that climate change would be beneficial up to 2.2˚C of warming from 2009 (when he wrote his paper). This means approximately 3˚C from pre-industrial levels, since about 0.8˚C of warming has happened in the last 150 years. The latest estimates of climate sensitivity suggest that such temperatures may not be reached till the end of the century — if at all. The Intergovernmental Panel on Climate Change, whose reports define the consensis, is sticking to older assumptions, however, which would mean net benefits till about 2080. Either way, it’s a long way off.
When I search for Richard Tol on Youtube, the 1st hit is some rando with 39 subscribers. I have more subscribers. What a despicable platform. Their corrupt algorithm picks a bad singer with 100 views over someone who has had over half a million views.
Looks like some of his work is accessible here;
https://profiles.sussex.ac.uk/p28981...l/publications
freebeard (03-14-2024)
