Old 04-04-2024, 05:24 PM   #8 (permalink)
Isaac Zachary
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
Originally Posted by jakobnev View Post
The Prius uses the HV-battery to start the engine.
That could possibly be the problem. But since there's no red triangle, and I'm not sure if the red triangle light even works, I guess I could try to connect with the Torque app to see if another module has failed.
However, a bad HV battery usually will still start the car, at least after unplugging the 12V and trying again. But I get zero response. The only thing that displays on the dash is the open door symbol.
