Old 06-01-2024, 02:07 PM   #1 (permalink)
capturedbyrobots
Aero attempt at stand up scooter
So I always wanted to dive into aerodynamics, and stand up scooters are like one of the worst aerodynamic vehicles. Standing tall and the wind just slows me down a lot. When I’m going fast I crouch down to try to get out of the wind but then I’m just a big low slug. The goped is only 41cc so I’m trying to see if top speed can increase with a front fairing. Eventually id like to play with this on my 70s mopeds but that’s another story.
I made the fairing shape to mostly cover me as I crouch down, it isn’t too side loaded for wind I think as it’s so rounded. But I’m no expert.
I made the frame out of a cattle panel, bent it and shaped it to be rounded as possible without sticking out past the beginning of the front wheel, it’s supported on the frame and on the top of the steering pole in a pivot bolt so it’s actually not tied to the steering at all. Steering just pivots and that way the fairing has some upper support.
This is the result. I’m going to skin it today with packing tape then heat gun as I saw in an old tv show where this racing wheelchair guy used it to make his fairings. If it seems to work I’ll use a layer of fiberglass or something to increase its rigidity.
Also if I need to add more of a blunt point to the nose I can add that easily to the existing frame. I’ll skin it then post pics and if I could get some advice as to the shape id appreciate it. Thx!
Idk why the pics are sideways lol
ID:	34742   Click image for larger version
The Following 4 Users Say Thank You to capturedbyrobots For This Useful Post:
Ecky (06-01-2024), freebeard (06-01-2024), Joggernot (06-02-2024), y2kbug (06-02-2024)
