Old 06-26-2024, 10:05 AM   #5 (permalink)
JohnForde
Great to hear from you Aerohead!
I appreciate your inputs very much.
I purchased ($200) a nearly ideally shaped inflatable but have decided against using it. It is pyramid shaped designed as an obstacle for paintball. The 12"W peak could be at the tail of air flow. The sides taper at 22 degrees to exactly 5'L. I would need to purchase a second one and stack the two of them.
I need to have easy access to load things in the van that is why I am building custom doors instead. I'll do another more in depth reply about the new door plan.
ID:	34798   Click image for larger version
ID:	34799   Click image for larger version
The Following User Says Thank You to JohnForde For This Useful Post:
aerohead (06-26-2024)
