Old 06-26-2024, 12:18 PM   #6 (permalink)
JohnForde
Aerohead 3 "the feathers"
At 48" behind the vehicle my 'whaletail' (WT) still has an aperture of 24" wide.
The 'feathers' eliminate the aperture. They will be hand rolled out before each highway trip. They will extend another 33-36 inches behind the lights. At the rearmost point they will rub against each other and can flex either way for the wind.
They are made of twin wall polycarbonate. They slide thru a 1/2" slot between two 1"x3" aluminum tubes that are the rear door frame.
They can be quickly retracted by hard braking. I can adjust this with the weight of the metal 'stop', that keeps the feather from tumbling out.
It has no top after the lights, just sides. I am thinking about how to improve this.
If the police pull me over I briefly (1/2 second) hard brake causing the feathers to tumble in and conceal themselves.
"Officer, I believe I am up to code in every way". And I am.
Name:	Feathers for Aerohead.png
The Following 2 Users Say Thank You to JohnForde For This Useful Post:
aerohead (06-26-2024), Piwoslaw (06-28-2024)
