Old 06-26-2024, 11:21 AM   #7 (permalink)
aerohead
' inflatable'
Originally Posted by JohnForde View Post
I appreciate your inputs very much.
I purchased ($200) a nearly ideally shaped inflatable but have decided against using it. It is pyramid shaped designed as an obstacle for paintball. The 12"W peak could be at the tail of air flow. The sides taper at 22 degrees to exactly 5'L. I would need to purchase a second one and stack the two of them.
I need to have easy access to load things in the van that is why I am building custom doors instead. I'll do another more in depth reply about the new door plan.
Qualitatively, you're rubbing noses with the Golden Goose!
At EAA's Oshkosh, 1997, at the International Space Station exhibit, a sign company had created an inflated, scale Space Shuttle, standing about 25-feet tall, of very accurate geometric exactness.
These aerospace-grade fabrics, like the bounce-house are constructed from, are perfect for creating a very 'aerodynamic' boat-tail.
