Old 06-27-2024, 02:34 AM   #4 (permalink)
Isaac Zachary
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
Why are you get the Golf driving again? Did the Avalon get too expensive to overhaul? On a sidenote, I didn't know you still had the Golf, yet I'd be intersted to know about the cold start ability in such an extreme weather.
The person I gave it to never changed the plates over. They gave it to someone else. Both lost interest. I just found out about it and it's still in my name. However, the long time sitting (6 years) may have caused more rust issues, externally and in the engine.
I had a 1,500W block heater on it. I would start the engine and have it at full operating temperature. The glow plugs wouldn't even turn on, except when I went to the store and came out and the engine had cooled a while. I plugged it in at work so no problem there either. The best thing is that it had instant heat as a result. I'd like to do the same thing to the Avalon but it seems a bit harder to figure out how to install a circulating block heater on.
