Old 06-27-2024, 08:50 PM   #5 (permalink)
H-Man
The brake pedal is evil
Denny's Detector - '08 Mercury Grand Marquis
Taserface - '17 Chevy Volt
Which would be easier: more solar panels or a super efficient heat pump head unit?
Suspect the 5C increase is in the central valley. They are changing the color of the land, fubaring up water sources and adding people.
Already have a heat pump and R20 on the walls. Might need to put an ERV in. If I do add to the cooling system, I'll see if I can add some space radiators to exploit the chill of space. Plan is to upsize the inverter to at least 12kW and add to the array, plus install 48V batteries. Might just go straight to 48V batteries and run the house on LiFePO4 during peak hours.
Getting sensor data off of a pre OBDII Toyota ECU via TDCL.
All of this is on E10: Project E is my current focus.
