Old 08-03-2024, 01:28 PM   #95 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
Originally Posted by JohnForde View Post
The current iteration has 14 degree doors. Still no effect.
If I understand correctly the stock rear trim is 17 degrees. Your structure is 14 degrees, and you have a taped panels to connect the two angles.
There is no effect because the flow is separating before it reaches your added structure. The stock 17 degree angle is too much.
