Thread: Solar power
Old 08-07-2024, 08:17 PM   #283 (permalink)
oil pan 4
I knocked the frames off my hail damaged panels. The Samsung neon black 330w panels use right about 5lb of aluminum each.
So it would see or maybe I'm wrong comparin 2020 tech to 2015 tech with my theoretical 240w panels on the first page to my modern Samsung panels. It seems to get the most efficient use of aluminum used just get the biggest panels you possibly can. If a 240w panel uses about 2kg a 330w panel uses 2.2kg and so does that mean a gigantic 430w panel uses 2.5kg?
Saving the world through increased consumption.
I think I made a post with that exact same title once.
