Old 08-26-2024, 11:14 AM   #141 (permalink)
JohnForde
Zevo done to 48"
UPDATE: The structure is done to 4' behind the rear bumper. Top and sides are all 11-12 degrees. Floor is foam and close to air tight.
I plan on adding tail lights and going 2 more feet in the next couple of days. Yesterday was too windy to test. I am heading out in an hour for a 60 mile test.
JSH suggested the VGs may be hurting. I removed one easily. I may remove them all.
I still need to improve the upper corners. Then add the 24" of twin wall polycarbonate to the tail. Should happen in the next 2 days.
ID:	35051   Click image for larger version
ID:	35052   Click image for larger version
ID:	35053   Click image for larger version
The Following User Says Thank You to JohnForde For This Useful Post:
aerohead (08-26-2024)
