Old 08-29-2024, 10:16 AM   #159 (permalink)
aerohead
' tubing'
Originally Posted by JohnForde View Post
Thank you FreeBeard! I am ready to buy the Perfect Prime digital pressure sensor and pitot tube at Amazon. I am having a hard time understanding/finding pressure disks. The inexpensive ones have 2 electric leads. I assume I need an air tube. is a better search term "Pneumatic pressure sensing disk"?
Scanivalve and ARC list many products and no prices.
Can you point me to where I can buy one easily? Big Box store? Amazon? EBay?
Thanks FB!
JF
The Pitot tube and static pressure puck / data-logger, may require different diameter Tygon tubing sizes.
And if you're going to measure velocity profiles at your static pressure measuring locations, you'll need some sort of manometer or a MAGNEHELIC, ,probably zero-to-3-inches of water column equivalency, depending on the unit of measure you choose. Dwyer will have whatever you want.
Sounds like VMan455 has you covered on 'pucks.'
