Old 08-26-2024, 06:15 PM   #151 (permalink)
All done including lights. slopes are 11 -12 degrees and 86 " L. Wake area width is 48"
I will test tomorrow. Here are pics.
ID:	35056   Click image for larger version
ID:	35057   Click image for larger version
ID:	35058   Click image for larger version
ID:	35059   Click image for larger version
The Following 3 Users Say Thank You to JohnForde For This Useful Post:
aerohead (08-29-2024), CigaR007 (08-30-2024), Joggernot (08-30-2024)
Old 08-27-2024, 03:22 PM   #152 (permalink)
Finished tail:
84"L
11-12 degrees
66" behind the bumper
Wake area 48"W x 58"H, Floor @ 33" above ground
Stock Zevo 9'H x 7'W.
Stock Avg power at 63 mph = 35 Kw
Tested today with VGs. 30 miles @ 63 mph = 38Kw
Removed VGs, 50 miles at 63 mph =35 Kw.
Disappointed but that's science!
Tomorrow I will finally have an observer and do tuft tests.
aerohead (08-29-2024), freebeard (08-27-2024), Piwoslaw (08-30-2024)
Old 08-27-2024, 03:44 PM   #153 (permalink)
Have you reviewed the thread linked at Permalink #125?
Old 08-27-2024, 05:18 PM   #154 (permalink)
Thank you FreeBeard! I am ready to buy the Perfect Prime digital pressure sensor and pitot tube at Amazon. I am having a hard time understanding/finding pressure disks. The inexpensive ones have 2 electric leads. I assume I need an air tube. is a better search term "Pneumatic pressure sensing disk"?
Scanivalve and ARC list many products and no prices.
Can you point me to where I can buy one easily? Big Box store? Amazon? EBay?
Thanks FB!
JF
The Following 2 Users Say Thank You to JohnForde For This Useful Post:
Old 08-27-2024, 07:12 PM   #155 (permalink)
Sorry. I'm strictly a [local] brick-and-mortar shopper.
The subject of sensor pucks was addressed by [banned] member Julian Edgar in hecomodder.com/forum/showthread.php/20-monitoring-air-fuel-ratios-std-wideband-sensor-5204.html
Here he promoted a book (see Section Two) ecomodder.com/forum/showthread.php/new-amateur-aerodynamics-book-25452.html
Notice Permalink #6 there. After you conclude your current experiment we can talk about this:
Old 08-27-2024, 07:36 PM   #156 (permalink)
Building a pressure differential test kit
I have 3 of 4 but do not know where to find the pressure sensing disc/patch. Anyone have ideas? Thanks JF
Name:	Screenshot 2024-08-27 at 6.32.36 PM.jpg
ID:	35062   Click image for larger version
The Following User Says Thank You to JohnForde For This Useful Post:
Old 08-27-2024, 08:27 PM   #157 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
You won't find these retail; you have to call Scanivalve and talk to a salesperson. They were inexpensive, maybe $10 or $12 per. Let me check the garage tomorrow, I might have some extras laying around--you're welcome to them if so. These along with tufts are very useful:
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following User Says Thank You to Vman455 For This Useful Post:
Old 08-27-2024, 09:13 PM   #158 (permalink)
Thank you VMan! I will DM my email address to you. JF
Old 08-29-2024, 10:16 AM   #159 (permalink)
' tubing'
Thanks FB!
JF
The Pitot tube and static pressure puck / data-logger, may require different diameter Tygon tubing sizes.
And if you're going to measure velocity profiles at your static pressure measuring locations, you'll need some sort of manometer or a MAGNEHELIC, ,probably zero-to-3-inches of water column equivalency, depending on the unit of measure you choose. Dwyer will have whatever you want.
Sounds like VMan455 has you covered on 'pucks.'
Old 08-29-2024, 12:00 PM   #160 (permalink)
Rainy here so with time on my hands I get wordier and my posts longer.
Amazon is selling me these 3 in the photo: Digital Manometer, Pitot & tubing. VMan455 is generously sending me pucks.
Tomorrow after the rain I shouid be able to do my first tuft test. Chaotic yarn will explain my lack of drag reduction. Attached flow would be perplexing.
In the mean time I have 2 theories: 1. Cuff needs smoothing, and 2. Corners leak to much air weakening sequestration. I will work on both today or tomorrow between rain showers. Then tuft test. Pressure test will have to wait a week.
I really am kind f surprised to see no improvement with 3 huge 11 degree slopes.
Thoughts anyone?
Name:	Screenshot 2024-08-29 at 10.45.20 AM.jpg
ID:	35079   Click image for larger version
Name:	Screenshot 2024-08-29 at 10.53.57 AM.jpg
aerohead (08-31-2024)
brightdrop, electric van, zevo
