Old 09-01-2024, 07:33 PM   #4 (permalink)
freebeard
...it seems your ISP has been bribed...
The Sci-Hub page loads correctly at this time at this location. My web browser has Ublock Origin baked in:
Raspbian Chromium extensions - Raspberry Pi Forums
Re: Raspbian Chromium extensions. Fri Sep 22, 2017 12:41 pm. They come with a RPI customisation made to make it more usable for general users. uBlock is one of them. I assume duckduckgo as a search engine. I cannot remember if flash is or is not part of that too. Possibly h265ify.
See also ecomodder.com: DIY Plasmoids
The aftermarket ignition system looks interesting but the description needs work
IONFIRE SYSTEM SPECS
INPUT VOLTAGE: 12 VOLT DC
POWER CONSUMPTION: 24 to 48 WATTS (depending on RPM)
OUTPUT VOLTAGE: ~ 550 VOLTS
DC PULSE CURRENT: 150 amps (Based on ignition cable resistance less than 4 ohm /ft resistance)
DIMENSIONS: 5.5in L X 3.5in W and 1.75in H.
Power supply Unit weight: 1lb 12 Oz. (excluding plasma distributor bricks)
The 4 cyl plasma distributor brick dimensions are as follows: 7.75in L, 2.0in W, 2.25in H and weight: 14 Oz.
The output jumps from Watts to Amps. The (2 cylinder? 8 cylinder?) unit is half the size but twice the weight of the 4 cylinder unit.
The pinout shows two leads per cylinder plus a ground. How does that work?
________________
Because much of what is in the published literature is nonsense,
and much of what isn’t nonsense is not in the scientific literature.
-- Sabine Hossenfelder
Logic (09-08-2024)
