Old 09-06-2024, 12:02 AM   #9 (permalink)
Logic
It takes a lot of dirt to lose even 5% of output.
Dropping them vertical is going to lose up to half of output.
You can always count on matt ferrel to boost any dumb idea that comes his way.
Hmmm... I haven't gone into this deeply and ferreted out the actual numbers from the research institutes involved, but:
https://vertical.solar/energy-yield_new
Now I'm thinking:
What happens if you combine the solar reflective paint discussed elsewhere with Vertical Bifacial Solar Panels:
The 'roof' would still have a very good 'view' of space, plus some shade for a lot of the day
AND
Should improve the output from the solar panels..?
IIRC Solar actually uses the IR frequencies best radiated by this paint..?
ie: You would be turning some of the house or even car heat into electricity..?!
