Old 09-16-2024, 11:41 AM   #4 (permalink)
aerohead
At the dealer lot
The local dealership had one in stock, outside in the heat. $96,000, with all the whistles & bells.
* 205-kWh pack [( 6.082-gallon-e (gasoline)], 5.111-gallon-e ( Diesel )
* If this is the '440-mile range, EPA COMBINED, that gives an indicated 465.9-Wh/mi, @ 72.342 mpg-e.
* If regen constitutes 20% of the range, as in the BOLT, then, we're looking at 352-miles range @ constant-velocity, and 582.3-Wh/mi, @ 57.873 mpg-e.
They rate the Silverado @ Cd 0.33, which seems reasonable, considering all the visible 'tweaks' to the body, especially the underbody.
Some local pickup owners are already spending $87,000 on 'King Ranch' F-150s. An extra $9000 probably wouldn't ruffle them.
Piotrsko (09-16-2024)
