Old 10-02-2024, 09:05 PM   #9 (permalink)
Logic
Ozone:
Interesting here is:
Efficiency went way up when the concentration of Ozone in the reactor was low... as it would be in an intake tract.
A DBD also gives you flow... into the engine. That kills 2 birds with one stone.!
I'm 'seeing' a DBD modded intake tract that helps flow air AND ozone into the engine.
Energy efficiency of an ozone generation process in oxygen. Analysis of a
pulsed DBD system
https://sci-hub.ru/https://www.scien...42207X1830366X
Here is VirusTotal's opinion on the above link:
(The opinion of around 60 legit AVs and bad URL databases)
If something is telling you the link is suspect; suspect that something instead.
https://www.virustotal.com/gui/url/1...2f0e?nocache=1
