Old 10-12-2024, 07:55 AM   #9 (permalink)
Logic
I have a series DC motor so when i power along i have up to 75 kw coming out of the Battery as DC. Makes everything holding current magnetic. Tore apart the first set of cable restraints. Hundred ft of large diameter wire wound into a coil makes a massive magnet if I can restrain that and everything else magnetic
Ok so this is in your car?
Is it an EV? A home made EV? A hybrid?
Sounds extremely interesting!?
Are these "cable restraints" inside the motor, or the leads going to/from it?
As I understand magnetic 'shielding' you need a certain minimum thickness of ferrous metal around your field so the unused 'outside' field can 'concentrate' in that and not bother with going 'into the surrounding air'.
Sounds like your motor doesn't have enough of this??
