Old 10-19-2024, 01:43 PM   #28 (permalink)
freebeard
for every liter of fuel burned your engine produces about a liter of water.
A lot of that goes past the piston rings
Hyperbole much?
adpistonring.com: Piston Ring Joint Configuration
The butt cut used in automotive applications is least effective. a step cut or sure-seal joint for the piston ring is better. The tri-lap seal is used for steam.
aerohead (04-05-2025)
